Post up your avg. Xsmn temps
Jkieffer
2017 8 Speed Express after 30 minute highway.
Hemi395
Cape Cod MA
This was towing my TT home for the first time. 3100lbs dry, 21ft. Trans temps never went above 145 which I thought was pretty good. This is the 65RFE with a MagHytec trans pan running Redline C+.
lukedukem
Victoria, Tx
Id say so.
Here's mine after a 20 min. tow of my TT that weighs about 7100lbs.
note that oil pressure and temp. never seen it at those levels.
(Hemi/8Speed and 3.21, CC, 4wd)
Luke
huntergreen
Have a question guys. Since I have never heard of an EVIC giving an accurate mpg reading, how can we assume other info taken from the EVIC is accurate?
Hemi395
Cape Cod MA
I have booked a scan tool up to my truck and the values are identical. My Trinity also shows the same values. So the temp values are accurate
wink
Beast Pilot
Golden, Co
2017 1500 Sport RCSB
The temp is just a voltage from the sensor, so it should always be accurate. Avg MPG is an approximation of how many gallons are in the tank. So I trust it less than the old school method of checking MPG.
wink
liftedpsd2010
heme
2017 hemi here's my temps after about a 30 mile round trip.
Sent from my KYOCERA-C6742A using Tapatalk
Rupert
Annapolis, Md
2014 big horn
My trans runs about 185 , up to 200 when towing long distance. I have a 180 deg tstat and tune
The 8 speed has a thermo disk that is designed to heat up the tranny quicker using coolant and also maintain the optimum temp of 190 deg.
liftedpsd2010
heme
Id say so.
Luke
Man I wish mine had that gauge cluster. That thing looks so much nicer.
Hemi395
Cape Cod MA
^^^Love the premium guage cluster. IMO if anyone doesn't have one it's well worth the upgrade
liftedpsd2010
heme
How do you upgrade it and retain your mileage? And how expensive does it run? Thanks sorry to hijack thread
Hemi395
Cape Cod MA
That's an excellent question. I believe there is a way I'm just not sure what that is since mine came with this cluster
R.L.K.
R.L.K.
Bristol , Tn.
Bump
U&A
2016 3500 SRW
6.4 HEMI
Awsome picture bump. I think thus pic came from you RLK on another thread.
R.L.K.
R.L.K.
Bristol , Tn.
Ha , I was just looking for that for you on the synthetic oil thread LOL . I believe Rampant posted that originally .
Reactions: U&A
U&A
2016 3500 SRW
6.4 HEMI
It just saved me a lot of heartache. I was flipping out looking fir it and rememberd i saved it in my photos.
So i ended up draining more than i thought. I was supprised to see how much of a diff it made just adding small amounts.
R.L.K.
R.L.K.
Bristol , Tn.
Thanks
Bama_ram_1500
Alabama
2014 Ram 2500 4x4 SLT
66RFE 6 speed xsmn
68,000 miles
I just had trans work
done lately but before the work mine ran 180 consistently. That was both towing and empty.
I just had to have the soleniod pack and torque converter replaced. The temps seem to not rise as fast now. Towing I will find out more this weekend.
U&A
2016 3500 SRW
6.4 HEMI
What was happening that showed you needed the trans work on? Thats a bummer dude. Good luck with the new parts
