Power washer help
Discussion in 'Garage' started by Jwithing, Sep 5, 2017.
  1. Jwithing
    Jwithing Supporting Member
    869
    282
    Mar 27, 2017
    STL
    Ram Year:
    Engine:
    Hey all,
    Need some help getting my power washer running, I'm at a loss. At the end of last season, it would start but die immediately. I finally got around to looking at it. I dismantled and cleaned the carb, changed the gas, oil, and sparkplug, and cleaned the air filter. I used pump saver in it as well. I can't even get it to run. It'll turn over and act like it'll run, but doesn't fully startup. I tried spraying carb cleaner w/ the air filter off and no difference. It's an expensive unit, so I'd like to get it running vs. buying a new one.
    TIA
  2. Pull Ya
    Pull Ya Supporting Member
    5,132
    2,628
    Jan 16, 2012
    Cedar Creek, Tx
    Ram Year:
    Engine:
    Did you put a new gas line on? They clog up pretty easy after the engine sits for awhile.
    Jay
    Skubasteve! likes this.
  3. BlkZrx
    BlkZrx Senior Member
    65
    244
    137
    Jan 17, 2016
    northeast IN
    Ram Year:
    2016 2500 SLT Std. cab
    Engine:
    Do you keep relieving the pressure in the wand? Mine does that when cold. Helps if you keep the nozzle open till it's running well..
    Sent from my LG-K540 using Tapatalk
  4. Jwithing
    869
    282
    Mar 27, 2017
    STL
    Ram Year:
    Engine:
    Yup, already considered :)
  5. Jwithing
    869
    282
    Mar 27, 2017
    STL
    Ram Year:
    Engine:
    That could be worth checking out. Didn't think about it since gas came out when I disconnected to clean the carb, but it could have been residual after a blockage. I'd still expect it to startup after putting some carb cleaner directly into the carb. After it sits for a minute or so, it'll act like it's going to start, then nothing.
    Pull Ya likes this.
  6. chopperman1
    chopperman1 Senior Member
    317
    87
    Dec 26, 2013
    Ram Year:
    2016 Rebel
    Engine:
    5.7L HEMI
    Carb cleaner will not help start an engine, exact opposite actually. Get some starting fluid, spray a blast in the carb, if it starts the issue is gas related, if not then it's spark related.
    CostaRam, Avgas and SYKRAMMAN like this.
  7. SYKRAMMAN
    SYKRAMMAN Senior Member
    624
    86
    Jul 10, 2017
    Jersey shore
    Ram Year:
    02 qcsb slt 3.92's
    Engine:
    4.7 Puppy
    ^1 Take the plug out,put it against the head,pull start cord n see if you have spark.
  8. averageguy
    averageguy Senior Member
    539
    209
    Dec 15, 2014
    Belleville Mi
    Ram Year:
    Engine:
    hemi
    Did you actually take the jet out and make sure it wasn't plugged? Mine was stopped up last spring from sitting over the winter and have had this problem with other small engines. As stated, check for spark and use starting fluid. Do you treat your gas against ethanol damage? Stabilizers alone don't treat the ethanol problem. I have replaced one carbureator on a weed eater and one on a leaf blower.
  9. Skubasteve!
    Skubasteve! Senior Member
    290
    112
    Jun 18, 2017
    Ram Year:
    Engine:
    I had a fuel filter go bad on my echo leaf blower, caused all sorts of issues and of course it was the LAST thing I checked. Didnt even know it had one.
  10. Avgas
    Avgas Senior Member
    484
    164
    Sep 21, 2015
    Ram Year:
    2015 Express
    Engine:
    3.6 Pentastar
    +1
    Use starting fluid, if it wont turn, check ignition coil.
Share This Page
