Power window crazy problem... need help!
Tom24
NH
I have a 2016 Big Horn, the drivers power window was working fine and go down and up properly till one day the window would go down when pushed and then stop after going about 3 to 4 inches, I can push again it it does the same thing, same with going up, all other windows work fine. I tried the relearn of down and hold and up and hold for the one touch and that did not solve problem. The problem happens if I use the one touch or hold the switch. I removed the motor and ran it to rule out regulator binding and it did the same thing. I'm thinking it's the door module but don't want to spend money on that if it won't fix the problem. Has anyone had this problem and what was the fix.
SitKneelBend
St. Louis
3.6 Pentastar
Are you saying it freezes when going up?
T
Tom24
NH
@SitKneelBend when using the window I push the switch for down and the window will go about 3 inches and then stop, I push and hold switch and it will go down 3 inches then stop. I have to keep repeating this to get window all the way down and have to do the same thing to get the window up.
U&A
2016 3500 SRW
6.4 HEMI
Re set the regulator
Hold the up button and get the window all the way up but do not release the up button when its fully closed. Keep holding the up button for a solid five seconds and then let go.
They see if its fixed.
When the window is rolled all the way up and you continue to hold the button for five seconds or more it’s supposed to reset it. I have issues with the auto up and down working. Resetting it fixes the problem. I think a lot of it is from rolling your windows up and down when going over bumps and the sensors on the window regulators start to freak out.
RamCares
n/a
n/a
Hi @Tom24, we can definitely understand how this would be frustrating. While we understand that you are reaching out to your fellow forum members for support, we recommend a proper dealer diagnosis in order to determine the root cause of your window concerns. Feel free to send us a private message for support if needed!
Kathryn
Ram Cares
Livinalittle
Ontario
2013 Sport, 6 speed, 4x4, 3.92
+1 on resetting the regulator. My daughter decided to roll the window up on her stuffy one time (that's a separate issue in itself) and I had the same problem after. Quick reset and it was good to go.
U&A
2016 3500 SRW
6.4 HEMI
+1 on resetting the regulator. My daughter decided to roll the window up on her stuffy one time (that's a separate issue in itself) and I had the same issue after. Quick reset and it was good to go.
[emoji23][emoji23][emoji23][emoji23][emoji23][emoji23][emoji23][emoji23]
Hope you dont have any pets[emoji16][emoji16][emoji16][emoji23][emoji23][emoji23]
SitKneelBend
St. Louis
3.6 Pentastar
It stops and retracts for pets, my dog likes to roll himself up occasionally...
T
Tom24
NH
I did the reset and still have the problem, any other thoughts?
Reactions: U&A
U&A
2016 3500 SRW
6.4 HEMI
Stop rolling the window up and down. Wont do it anymore then....[emoji16]
Ricks Ram
It sounds like it could be your door module. Ot could also be the switch but I would think it's unlikely. I have several doir modules and switches left over from doing power folding mirror upgrades and I would be happy to send you one to try but we are in the process of having a house built and they are packed away somewhere and I have no idea where they are until I unpack everything. Maybe someone who has a spare will chime in and send it to you to test. If you have the Alfa tool you can use it to check for DTC codes to see if any are present. At least this way you won't just be throwing parts at it.
Sent from my SM-G981U1 using Tapatalk
T
Tom24
NH
Thanks Rick, I have power folding mirrors, the module I need is 68225103AC. I have been checking the system and can hear and feel the module click for the auto down then click off after window travels 3-4 inches so the switch is not in play as the auto down function starts so I believe it is the module.
T
Tom24
NH
UPDATE .... I took the window motor from the left door and plugged it into harness on right door and used the right door switch and module and the motor just freewheeling did the same thing. I purchased a new left window motor and it fixed the problem. I was surprised that it was the problem, I can only guess it was the circuit board in the motor causing the problem. I hope this helps anyone with the same problem. Thanks for all the help.
[email protected]
Cape Coral FL
I had an issue similar to this on my 2017 Laramie. I saw on forum awhile back that seems to work for my issue, may work for others. Press window button up until you hear it click twice(you can hear it if it's quiet), then down all the way until it clicks twice, repeat. Has never failed me.
T
Tom24
NH
I tried doing the window auto down/up reset and that didn't work for my problem.
