Probably already answered somewhere but...
regal81455
Illinois
What is the tallest lift one can get that will still clear a 7' clear garage door opening w/ a 16' Laramie? Is this an easy answer?
My 16' does have the shark fin antenna so I know that will impact the decision.
Guess what I'm asking since I'm a newbie when it comes to lifts is - if I measure from the top of the shark fin to the bottom of my opening and it's say 2.25" - is it safe to assume a 2" lift will give me exactly 2" of lift or is there some tolerance there that could ultimately make it a no go?
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
I can measure my door at lunch, my shark fin barely clears, but it does.
I will measure mine at lunch today for ya.
kurek
Northwest
If a lift relies on a spacer, either on top of the strut or on top of the rear coil spring, or on simply relocating the spring seat with your stock spring (Bilstein front struts) then a 2 inch lift is going to lift the truck 2 inches.
But any lift that incorporates new parts like aftermarket springs, etc is going to supply a different amount of lift depending on the exact equipment in your truck.
I put a "two inch" Mopar kit on my RCSB 4X4 and got slightly more than 2 inches, but still could drive safely into my garage.
regal81455
regal81455
Illinois
Thanks for the insight - this is what had me concerned. I appreciate your confirming my suspicions!
JB1
Houston, Texas
It kinda depends on tire size too
regal81455
regal81455
Illinois
And that also was something I was concerned about but I'm running stock 20s w/ the standard 275/60/R20s ( 33s ) for now.
Graygoose
Oklahoma
Convert, for now.
small
So went home, my garage door opening is 6'11"
and I fit, with shark fin.
Mines 4.5/3" lift, and 35" tall tires
Graygoose
Oklahoma
Convert, for now.
small
You betcha sir. My grandkids love the "twang!" the antenna does when it bounces off the header of the door, but it fits!
JB1
Houston, Texas
I have a 5” lift with 325/60R20 and mine won’t fit, my garage is 83”
regal81455
regal81455
Illinois
This is all great info - looks like I should be able to put on a 2-3" lift then w/o too much concern if I decide to go that route. Thank you everyone for all your input!
I was mostly considering an eibach lift kit + maybe a 1" spacer for a lil' extra??
