Question regarding leveling kit
JoeyG
I'm thinking of installing a leveling kit on my 04 4x4 so I can install a set of 35's. On some kits I saw they give you blocks for the rear. Are these necessary?
Also those of you that installed the leveling kit, any premature wear on ball joints and tie rod ends?
thanks!
NWRQC
The rear blocks will keep the factory rake if you use them.
Just crank you torsion bars about 2" until the truck is level and call it good. Buy some new shocks and have the alignment done and you're set. I've never had any problems with premature wear.
J
JoeyG
Thank you sir! You running 35's as well?
NWRQC
I'm running 305/55/20's which is about 33x12x20.
Orca
