Questions about replacing CV Axles…
ClassicJoe
NC
I will be replacing both CV axles on my 2019 1500 Classic Big Horn 4wd… Both the driver and passenger side CV axles are the same/same process, correct? Also, do I have/need to replace the stub shafts, or can/should I be able to use the existing ones?
Thank you.
Dark Knight 500
Alberta
Correct. Both sides are the same process. As for the stub shafts, the only reason you would need to replace them is if they’re seized to the cv axle, or if they’re extremely worn. On a 2019 I find both these scenarios very unlikely.
