crazykid1994
alright so instead of blowing up a different thread I’m starting my own. I installed the v6 electric fan in my truck and installed a pwm controller to run the fan so at idle the fan doesn’t cycle on and off. That gives me better cooling characteristics due to constant air flow across the radiator. The ac compressor power gets tapped so the controller will run with the ac as well as stand-alone. Controller power is tapped to the accessory fuse power for the cab in the fuse box. Ran my own 10awg welding cable for the fan. Temps are after driving on the highway for 30 minutes then around town for another 30 minutes. 180° tstat installed and ags deleted
