Radio Locked, Please start the vehicle
MichalSidla
Sarasota
Hi everybody,
I have problem with screen. I tried unlock the battery, I tried reset with two button, but still not working.
On screen work only clima, but no settings, radio is locked.
But I can start and go. I can't find what can I do.
Is it 2014 Ram 5.7 Longhorn.
I can't go to the dealer, becouse I am from Czech Republic and we don't have Dogde Dealership.
8732cuts
US
Hi everybody,
Pull the fuse, on firewall near steering column. Only fuse you will see.
SitKneelBend
St. Louis
3.6 Pentastar
Hi everybody,
Is this radio new for you or has it been this radio the whole time?
IRSmart
I drink and I know things
Westminster, MD
2018 Power Wagon
6.4L Hemi
That’s not a factory fuse, or set of wires.
Dichu
Canada
I having the same issue. Purchased a RA4 radio from a Dodge Ram and installed it on my 2015 Jeep Cherokee. I’ve tried the steps above but no luck. Any suggestions would be appreciated.
SitKneelBend
St. Louis
3.6 Pentastar
Are you saying your radio is asking for an anti-theft unlock code?
Dichu
Canada
I’m not getting the option to input the code. This is what I get.
SitKneelBend
St. Louis
3.6 Pentastar
Are you taking the radio out since its not working? If so, leave it in for several days/driving cycles and see if it changes to allow code input. If that's not an option, seek a refund if possible.
Dichu
Canada
I was taking the radio out to determine the issue. I haven’t had it in the vehicle for more than 48 hours yet. Could it be an issue where I may need to do a force update or take it to the dealership to get it retuned for my Jeep Cherokee since it came from a Dodge Ram 1500?
SitKneelBend
St. Louis
3.6 Pentastar
It takes several power cycles and time for the radio to read the vehicle it's in and configure itself normally. You "should" be able to enter the anti-theft code immediately on install, but since its not prompting waiting may get it to display.
Benamer
Turkey
jeep Grand Cherooke 2015
6v
Hi everybody,
Hi, did you solve this problem? I have the same problem
myckee
Canada
I am in the exact same boat. I bought a RA4/VP4 radio from a 2013 Ram and installed it in my 2016 Cherokee. I have the same message that will not go away. I even tried updating the radio, which updated fine, but still delivers this message.
Anyone have any idea? Does the Jeep radio plug not have the same wiring as the RAM; as in it is missing a power wire telling the radio the vehicle has started? Or, is the radio too old?
SitKneelBend
St. Louis
3.6 Pentastar
Have you entered the anti-theft code and it still appears?
myckee
Canada
It does not give the screen whereby one could enter the code since it does not recognize the car is running.
I believe I know what the problem is though. I believe the problem is the 29bit canbus used in the Cherokee which is different from most other Chrysler vehicles, including the 2013 Ram, which uses 11 bit canbus signals. The 11bit canbus radio, cannot interpret the 29bit canbus signals it is receiving in the 2016 Cherokee, so it does not know the car is running. This is further proven by the fact the radio does not recognise that it is installed in a Jeep so it still displays the RAM logo when it powers on. The 11bit radio just cannot understand the 29bit canbus signals it is receiving.
SitKneelBend
St. Louis
3.6 Pentastar
2013 RA4 and 2016 Cherokee should be compatible. The 2013 was the first year in the RAM with the new CANBUS
myckee
Canada
The 2013 did get the new GPEC2 PCM, however it is still 11bit canbus. The Cherokee also has a GPEC2 PCM, and while the 2014 Cherokee does have 11bit canbus, the 2015, and up, Cherokee, have 29bit canbus despite having the same style GPEC2 PCM. It looks the same but the canbus is definitely different.
I have a small business selling programmed, plug and play, Chrysler/Dodge/Jeep PCMs, so I am well versed in this area.
SitKneelBend
St. Louis
3.6 Pentastar
All 2013-2017 RA3/RA4s "should" work. What is the part number on your radio? You may find this post helpful...
myckee
Canada
Thanks SitKneelBend. I have seen and posted in that thread. The radio updated fine to the newer software, despite being not unlocked and despite the start vehicle message. Even after updating, the same message remains. The part number, blacked out by chrysler, and revealed by myself with some alcohol, was 68184965AG. Probably blacked out since the software inside the radio, as reported in the update logs, is 68224537AK
SitKneelBend
St. Louis
3.6 Pentastar
Ah, a Frankenradio! I have seen this particular thing pop up across several UConnect models from the older RA3/RA4 to even the newer Uconnect 5 radios. Return and replace has typically been the solution that worked. The only other solution I might offer is if you have access to AlfaOBD is to try to write your VIN to the radio manually by connecting directly to the Radio Navigator Module.
