Thank you for the info, I am not that savvy at this I need a package and plug and play. I did add fog lights with the help of Grimm
The UAS or UAQ is a direct plug in item. I had basic radio and it was 15 minutes from start to finish. You do need the 8.4 bezel, which you can probably find here, on eBay or from infotainment. Steps are take 2 screws out of indent at top of dash above radio, pull bezel from that handle and it pops off, then take out 12-14 or so screws to remove AC unit, put AC unit into new bezel, screw new bezel to main console you removed in step 2, 4 screws to remove radio, unplug wires and main harness had lever that swings over to release, plug all that into new radio, 4 screws to put new radio in, bezel in console snaps back in place 2 screws in top, then turn on radio and enter security code. If you have SiriusXM call them and give them your model or serial number(can't remember which), and enjoy. If you have back up camera in rear view mirror you can have it appear in radio also, Mpgrimm2 has cable for that.
