Radio?
lewisfiremedic
My oem radio is going bad, just wondering if it's worth upgrading the dash unit and trying to get caps for the semi-circles on the sides of the radio for the bezel (avoiding buying a new bezel), or just take the easy road and get an oem replacement radio.
1500ram12
5.9L Cummins
I believe crutchfield has a dash kit that replaces the center section so you can add a double din radio for about $20 I think
Sent from my D6708 using Tapatalk
L
lewisfiremedic
Thank you for the reply, ill look on their site
justin13703
MD
Since your truck didn't come with factory navigation, you will have to get a new center dash piece from the dealership. The non navigation radios are din and a half size so to install a double din you will need the factory navigation radio bezel. You will still need the double din dash kit with it as well. Unless you're good with a dremel and custom stuff you can modify the one you have but that takes a good bit of skill and time.
adubree86
Indianapolis, IN
2017 Ram 2500
Custom is the best way if you can swing it. I'm working on one now. With this you won't have a gaudy black trim ring and you still maintain the bottom cubby. Just have to paint mine and install it.
[/URL][/IMG]
Treeshark
Maryland
2005 Ram 1500 ST 4x4
4.7 Magnum V8
Din? Haven't heard this one before. What is it?
justin13703
MD
It's the way radios are measured. Single din radios are the "normal" size aftermarket radios that aren't touch screen and don't play movies or anything like that. Double din radios are the ones that usually have a full touch screen and can have navigation and play DVDs. Unfortunately chrysler likes to put 1.5 din radios in their vehicles so it makes it a pain to try to install a double din.
The picture above shows the center bezel modified for a double din size radio.
hotkarl
4.7 Semi-Hemi
I bought one of those China made oem knock off all in one radios. It was great for the 6 months that it worked. One day it just went crazy and nothing worked anymore aside from the am/fm. I had no idea Dodge had a factory dvd/gps (RB1) that was compatible with my '02, had I known this last year I would've got one , so now I am shopping for an RB1.
CLIFF0RD
[emoji3][emoji3][emoji3]
CLIFF0RD
[/URL][/IMG]
What did you use as a back piece in the semi circles to allow the bondo to adhere? What materiel? How did you attach it to the back of the bezel? Just bought an 08 and want to do the exact same thing. But I was just going to plastidip it.
