Ram 2500 HVAC Heater Core Blower Box Replacement Question
JEEPDUDE
WISCONSIN
Good afternoon
This is my first post so hopefully I posted in the correct spot.
So I have a 2021 RAM 2500 2 Door Tradesman. The ac heater box was damaged in an accident.
The part number on the housing is 68499201AA 61038 AA443380-7300 0631
I found one near me with the part number of 68499202AA 61038 AA43380-7310 26?? I can not read the last two digits.
How can I find out if this will work for my truck? ANY HELP WOULD BE APPRECIATED
Also is there a place I can cross reference part numbers?
Mike Wenrich
Mariposa, Ca
2004.5, 2023 RAM 2500 Laramie 4x4
5.9 Diesel, 6.4 Hemi
You actually might try a RAM parts dealer. They would have the original part number and any cross reference and with the info you have on the other tank they might be able to tell you what the application was. Having just done a blend door replacement on my 2004 I know there are differences in whether they are dual or single control so the unit you found might be for a higher level, maybe Laramie, model and might not work with your controls.
