Ready to lower my new RT
PaulHuntzy
Tracy CA
Hi everyone. Here is my new to me 2015 Ram RT that I purchased a few weeks ago.
I want to do a 2/4 drop and need to know what exactly to buy in order to keep the best ride quality possible.
I was also told when these trucks are lowered the rear tires moved forward and sometimes get wobble or wheel hop at higher speeds.
If you guys can fill me in that would be highly appreciated!View attachment 224169
You're best bet,is to talk to Matt at Moes a vendor on here,he'll steer you straight and won't try to upsell you. If you have wheelhop afterwards Core makes some good locating arms that mininiumize wheel hop,if you encounter a high speed sway you'll need Inez's rear locating brackets as they'll correct the geometery issues that basically cause the rear end to try to steer the truck when lowered.Some trucks get away with-out needing the locating arms,or brackets,while the next identical truck will need both.It seems to be hit or miss with a lowered 4th Gen and whether they'll need either after lowering
hdoggie24
Huntington Beach CA
Lowered mine with:
-Belltech 2/4 drop springs and panhard bracket
-IHC “No Cut” rear control arm relocation brackets
-QA1 TS905 rear shocks
-QA1 TS514 front shocks
Rides really nice
That looks great. I like your set up. Were the shocks straight bolt on? Im looking for new shocks and have read about the QA1 shocks but not many people run them. Are the part numbers straight replacements or any mod needed to be done? I have the no cut brackets still to install as well. I've been reading mixed reviews about. How are they working at for you? Awesome ride. Thanks
ameldorf
Lenoir, NC
So far so good on the brackets. From what I’ve read IHC changed to a thicker bracket based on original reviews (can’t 100% confirm this). Either way, my experience has been good.
The part numbers listed for QA1s required no modifications.
hdoggie24
Huntington Beach CA
i got my brackets about 4 months ago. Im assuming they are the newer updated style, I'm hoping lol. THanks for the info on the QA1 shocks. I have just Belltech Nitro but would like something better. I dont drive my truck everyday. I see the Vikings but I think those are way overkill for what I need
Lil John
Seattle
Are you in Washington?
1SloRam
Ms
x2 on relocation brackets for rear. Mine are illicit customs. Little tough to install if you don’t have access to the right tools. Never ran without the brackets but judging from trucks around town without them, the wheel is definitely not centered. No wobble , no problems at all with brackets installed.
P
PaulHuntzy
Tracy CA
Lowered mine with:
Rides really nice
LOOK GREAT! Thanks for the info. Does the bell tech drop come with the lanyard bracket?
ameldorf
Lenoir, NC
Panhard bracket?
Yes, the Belltech 964 kit includes springs, panhard bracket, front bump stops, swaybar endlinks, and hardware.
P
PaulHuntzy
Tracy CA
Panhard bracket?
COOL, May sound like a dumb question but I am assuming the QA1 shocks make for a better ride quality then the Belltech drop shocks?
Mike Townsend
I'm not sure if I have a Beltech or what on my truck but it has a 2/4 drop. I am trying to figure out what to do with the bump stops. I have tried to get to the bump stop cradle to cut them off but there isn't room. The local muffler place wants 150 to do it and that is nuts. Anybody have any tricks to get them off?
I'm also trying to figure out the shocks I should get. I know the QA1's are supposed to be good but they are pricey. Are those the best one's to get?
ameldorf
Lenoir, NC
Can’t personally compare to BT, but they ride batter than the factory after lowering.
I used a sawzall with wheels removed.
abouttobeglue
Same, Diablo blades cut through it easy
