I bought an 03 Ram, it has 120k miles... good running truck. Anyway,
Front Blinkers work fine.
Rear blinkers ...NEITHER side works. Hazards in the rear dont work.
Changed the bulbs, Nothing.
The taillights and brake lights work perfect. No trouble.
just the rear blinkers. I have no idea what it could be.
I even took apart the steering column, to access the MFS (blinker switch) and pulled it off. Cleaned it... still nothing.
Looks like the prev owner hit a pole and ripped the right rear taillight assembly off. Why would this affect the left side blinker?
I checked the plug connections, i also traced the taillight wire bundles looking for a ground wire. No ground wires?? It has to be a loose ground, but i cannot find a ground wire.
I checked the fuses, theyre fine.
