trooper1954
- Dec 4, 2015
- 10
- 0
- 2008
- 5.7 Hemi
Hi,
Problem began when I changed a 20 amp fuse that had blown for the rear passenger power point.
After replacing it, I now have no brake lights/overhead brake light while truck is running, and when the truck is parked and the ignition turned off, the brake lights remain on as tho on a time delay for about 5 minutes. I have also lost my time delay on my headlights once the truck is turned off. I'm tempted to think that while I was checking the fuses (I only checked the 20amp ones) I may have returned one to the wrong slot?? Any ideas or help would be appreciated....I'm going to disconnect the battery for awhile and see if this makes a difference.
Thank you.
Thank you.
