Rear Sway Bar End Links
jlis
Los Angeles
2014 Laramie
lmao. I might order the hellwigs i am going to go under my truck today and see how they look only bad thing is i have the factory swaybar. Should i order the sway bar too???? Hmmmmm
yes!
jlis
Los Angeles
2014 Laramie
Are you going to try just the rear end link or the front as well?
BlownGP
Houston/Baton Rouge
LMAO. I might order the hellwigs I am going to go under my truck today and see how they look only bad thing is I have the factory swaybar. Should I order the sway bar too???? hmmmmm
I really think the front hellwig bar is only a little bigger than stock. The rear is what makes all the difference.
I too was looking from some better end links for when I get a rear sway bar. I assume those hellwig links work for a stock height truck too?
BlkRamRt
SoCal
HEMI 5.7
they should depending on the length of the factory ones. you can adjust them to the same length.
DavidRam
SoCal - Redondo Beach
2012 RCSB
The 8-11 ones will work. Plus, you can adjust them down to 8.5" for when you lower it, soon. ;)
DavidRam
2012 RCSB
Yes, but if 8.5" is perfect 8" is a little short (that's what she said). ;)
I was referring more to the difference in length (I know it's very slight) when we move the end links from soft to aggressive on the sway bar... When set to the most aggressive, the back of the sway bar would be pulled up and a longer end link would allow for it to adjust back to level.
Again, my mind is all on my audio so I could be wrong, maybe I should just **** and go install my subs! :roflsquared:
LMAO. I might order the hellwigs I am going to go under my truck today and see how they look only bad thing is I have the factory swaybar. Should I order the sway bar too???? YES !hmmmmm
My bad, I was ass backwards with my above statement. More aggressive would require an end link shorter than 8", less aggressive would require an end link longer than 8".
Who the **** wants less aggressive?! I ordered 6"- 8", lol!
BlkRamRt
SoCal
HEMI 5.7
I was under my truck yesterday and I was seeing on how the end links were set up and yeah the 6to8 are the ones so far. I am going to order mine too.
jlis
Los Angeles
2014 Laramie
Is there any difference in the bushing between hellwig and energy suspension? Is one better than the other?
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Did anyone try these, and are they quieter than the BT squeaky ones?
BlkRamRt
SoCal
HEMI 5.7
they both seem to use polyurethane bushings and the energy endlinks are shorter than the hellwigs.
WhiteBuck
WA
Hemi, 8spd, 3.92
I just got mine in, I bought the 8-11. It came unassembled so I'm sending it, the hellwig bar and brackets to be powder coated silver
DavidRam
2012 RCSB
Hey hey! That's gonna look great! Make sure and post some pics, please.
I am guessing you aren't lowered, hence the 8-11?
DavidRam
2012 RCSB
They're in!
These things are beefy. The sway bar is level to the road, I'm not talking level to the eyes, but level with a level. :roflsquared:
The Q
The Q
South Texas RGV
2014 Sport R/T
The bushing in the Hellwig's look like they are urethane rather than rubber like the BellTech's.
On another note? Have you had any issues with your Spohn PanHard bar loosening up? Their instructions say it can loosen up and needs to be checked occasionally. I saw on one of the forums some mentioned using lock washers to help solve the problem.
DavidRam
2012 RCSB
The Hellwig bushings are definitely urethane.
No problems with the pan hard. But I probably over torqued them and also used Loctite, lol.
Btw, I love how they match the pan hard, and control arms! :)
Nice find man, thanks!:favorites13:
