Recovery/tow strap recommendations
PippinAin'tEasy
"Those aren't supposed to come off."
"Yeah."
WTF else can you say? Priceless.
"Oh, sweet debt. Thy name is Truck."
Skrap
Orange County, CA
2015 Laramie MegaCab 4x4
I carry 3 tow straps in my truck. I have collected them over the years from my prior off road Blazer so why not keep them in my 2500. Also there is a chance if they need to be used I will or the stuck person will be more than 30' into the "****". Can never have too much strap. I also have several large shackles. As someone else mentioned chains and cables can whip back but is still feel more safe putting a blanket ormother large item over the straps just in case something breaks. What of a tow hook breaks or part of someone's truck under heavy load. I don't want that coming at anyone vehicle, especially mine. If no blanket or similar tie a piece of rope to the middle of the strap with a 3' log tied to it dragging on the ground. Really anything to deaden the energy of a strap breaking will help the whip of a broken strap.
There are certain "straps" made for a running start to yank someone out of a situation. I mostly see them with guys stuck in deep sand. Wouldn't use any old strap for that though. Great video posted earlier.
02Steve15
02Steve15
Connecticut
So these were basically the only two i saw at home depot today. I may just get two of the previously mentioned straps in this thread
Kidder
DFW, TX
Hemi 5.7, eTorque
The bottom one is not a tow strap. It is a tie down strap. It says 10k pounds but I don't know if I would trust it. I have one like the top pic and I pulled an Explorer out of deep snow with it.
kg93
AZ
i have arb snatch straps for my truck but i also have cheapo homedepot tow ropes with hooks on them for pull out light weight vehicles and on my atv. Basically so i can be lazy and not deal with d rings.
But for pulling out big boys i get a nice running start with the snatch straps
02Steve15
02Steve15
Connecticut
I'll probably get the strap mentioned in the OP as well as the arb snatch strap
kg93
AZ
Oups!
Saw this clip after. Make sure you watch until the end
[yt]r_-fUPY4mjc[/yt]
i love that video lol. I love how stupid the chevy guy is though. All he had to do was throw it in neutral
Lethalweapon100
NY
V8 5.9 Magnum
Not sure if anybodys said it, but do not tie off to a tow ball.
You can tie off to the ball mount without the ball in it. You can get a piece of square tubing to go in the receiver with a d ring. You can get a hook or an eye from tractor supply to fit your receiver.
A tow ball is brittle and will enter your rear window at 60 MPH.
Sent from my SM-G920P using Tapatalk
02Steve15
02Steve15
Connecticut
Any pics? I want to make sure i do it the right way if i have to do it. I can take the ball out and tie the strap into that and/or just go through the receiver without the hitch in the receiver?
bcbouy
pitt meadows/100 mile house
2021 power wagon
hemi
most high quality tow/ snatch straps loops will fit inside your receiver and you can lock it in with the pin.i use lifting straps i get free from the hiab trucks because they expire after a few years,and they can't use them, and they're great for anchoring your truck to a tree or stump while i'm winching someone out.they have zero stretch,but i warn guys ahead of time and they just want to be unstuck,so they never say no.it's so much easier pulling than setting up the winch,snatch blocks etc.as someone else stated,NEVER loop it around the ball.
14hemiexpress
6.4l
Not my truck but this is what I do.
  • 129-1307-01 low-buck-liberation-getting-unstuck tow-strap-in-hitch-pin-1.jpg
02Steve15
02Steve15
Connecticut
So you would just put the pin through the loop.. The pin will hold up fine?
kg93
AZ
yes just think, if your towing something #15000 and that pin is the only thing holding it in there, and it does just fine
02Steve15
02Steve15
Connecticut
Must be pretty strong then.. Wouldnt want it to bend or whatnot, then you cant get it out lol
kg93
AZ
lol dont get a locking one then. I have a locking one and its been stuck in there for months. Nothing will loosen it, so now i need to cut it off.
14hemiexpress
6.4l
Yeah if you put one of those big d ring on there or a big hook that pin is still holding it. I haven't had any issues and I have had it 4lo rocking a 10 year old crape myrtle and that thing had some serious roots I broke the metal hook on a 2 in strap my 30 footer wouldn't reach by it's self. And that pin went no where
02Steve15
02Steve15
Connecticut
Any type of d ring or just something that looks like it will hold lol
02Steve15
02Steve15
Connecticut
I have a lock and a non locking thing i can put on it but regardless if it's locked or not, if it gets bent where you hook the strap up on the pin, you wont be getting it out of the receiver
derag2
6.4 hemi
Same thing can be said about the ball everyone is saying not to use......
Never seen or heard about a ball breaking... I have a 2 5/16 pintle combo that strap goes on and close the pintle... Or I've done the pin in the hitch as well...
