14Fiveseven
Im trying to upgrade from the 3.21 gears currently on my 2014 ram 1500 2wd running 35s. I have found some oem 3.92 axles or a yukon 3.90 kit. I have found a kit on jeggs performance for $1,300 that includes everything I would need (I believe). Will provide link below. Is this a good kit and would it be a kit any knowledgeable shop could install? I have seen some used rear axles with 3.92s and was wondering if that was a better idea. Since everything is already set up and the price is almost the same. But then again they have been sitting and might cost more to install. Don’t know which route I want to go. What have you guys heard about yukon and their kits as well. Thank you very much
https://www.jegs.com/i/Yukon-Gear/807/10482/10002/-1
