Remote start
crazykid1994
yea it’s best to death but... tested my rf hub. Have model
68319677AB. Some pages say this one will work. In Alfa i enabled remote start, Enabled hood latch present, reset rf hub after, installed a jumper across the connector under the hood where the hood latch goes. Can’t get truck to remote start. What should I look for? When I hit the button it just locks my truck
1500ram12
5.9L Cummins
If you have a 17 or 18 then it sounds like you did everything right. Go for a quick drive. Cycle the truck on and off a couple of times and it should work after. It took mine a drive with a couple cycles for it to take
2018 2500 6.4L Tradesman
crazykid1994
crazykid1994
Yea it’s a early model 2017. I’ll give it a couple key cycles. Hopefully it works.
crazykid1994
crazykid1994
Alright. Couple key cycles. Now it says hood latch open but I have a jumper in the plug under the hood. I’m lost here
Jimmy07
Under CBC I/O Usage- hood ajar switch usage, what are you set at- 1k or 500ohm? Whatever it is, switch it, take it for a drive, then try again.
EDIT: I guess first thing I should ask, have you made sure the wiring goes from that plug ALL THE WAY to the BCM?
crazykid1994
crazykid1994
I did not follow the wiring all the way back to the bcm. I have to check pin 11. Was just reading up on that. Don’t know how I missed that. Just glad my rf hub works for remote start. It’s set for 500/500. I tried 1k but same thing.
crazykid1994
crazykid1994
No wire in pin 11. Go figure. Guess I have to order a pin out or order the 200$ kit. At least I’ll get 2 more remotes but all I want to do is ground that pin. I’m not worried about running the whole harness...
Jimmy07
1500ram12
5.9L Cummins
@Jimmy07 do you know of hand what part number for pin 11?
I can look later, depending on what it is I may have 1 I can send you save you a few bucks
crazykid1994
crazykid1994
[/QUOTE]
Haha never mind, I look later I may have one
Let us know. It won’t be till tomorrow morning for me to look for one, but one of us can probably send him one
That would be awesome. I can PayPal one of y’all. I’ve got it rigged temporarily with some 18awg stuffed in the slot. Surprised it even worked. Just gotta order new fob rubbers with the remote start button
1500ram12
5.9L Cummins
That would be awesome. I can PayPal one of y’all. I’ve got it rigged temporarily with some 18awg stuffed in the slot. Surprised it even worked. Just gotta order new fob rubbers with the remote start button[/QUOTE]
I do have some. @crazykid1994 sending you a pm now. Don't worry about any payment
VICS
Chicago
Anyone have pic of pin 11? Where is it?
Thx
Vic
FDNF
Canada
Ecodiesel
Am I reading this thread right??? If I wire the hood connector to read closed, and use the alfaobd app to turn on the remote start, and refresh the RFB, is that all that is required to activate the remote start??????? It sounds to easy.
Cheers
Curtis
1500ram12
5.9L Cummins
Cheers
Curtis
As long as you have a 2017-19 classic. All you'll need beyond that is a key Fob overlay with the remote start. You can find them on Amazon for about $12
2018 Ram 2500 6.4L Hemi Tradesman
Jimmy07
Cheers
Curtis
Yes, for 2017+ rams only, though.
