Retrofitting my 2011
RAMdriver
Thanks JJ! Just received my set up yesterday. Projectors and 6000k HID kit. :banana-mario:
I am off of work all next week so Ill post pics of the project. 225F for 15-20 minutes should do the trick, correct?
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
that will do it! ;)
WhiteExpress
Midland, TX
Don't be afraid to bake it, open it a touch, and bake it again.
Like 400 times. Holy crap it takes forever on the first one!
R
RAMdriver
Nice, I cant wait to get this started.
BAILEY1
St Tammany Parish, LA.
2017 RAM 2500
Dat Cummins!
Can't wait to see them! I did mine last week and it was a snap. Thanks to JJ!!
R
RAMdriver
How long did it take you to do yours? Im not going to be painting anything.
BAILEY1
2017 RAM 2500
Dat Cummins!
I baked them apart on Friday night and started Saturday morning. I was done putting the projectors in at about 2, but I had to wait until dark so I could make sure my cut offs were straight before coming back to the house and hitting them with 2-part epoxy. After an hour of dry time on the epoxy, I tighten the nut on the back of the projectors and sealed them back up that night. I had everything installed and running before lunch on sunday.
I guess if I would have had a garage or a place to adjust my cut offs then I would haven been done by Saturday night.
R
RAMdriver
I am starting the install now. I have the housings in the oven right now. Hopefully this part goes smoothly, I constantly check them to make sure they are not melting.
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
I've.............never melted a set of lights.
Hundreds, dare I say even a thousand have been through my oven. The key is obviously temp and time. I've read some people say 350 degrees.........what? you cooking a chicken too? ;)
250 degrees. Hell, I left a light in the oven once for about.....30-40 minutes once (forgot to set my timer.....derr) - came out fine.
Tip - I use a silicone mat. That on a cookie sheet has served me very well over the years, in fact.......I'm using the same exact cookie sheet and silicone mat that I started with. It has one blemish on it......those pesky 2013's have some weird glue in them......some spooged out.......and its a ***** to remove!
R
RAMdriver
I had them in there for about 18 minutes and have broken the seal around 3/4 of the housing. They are going back in for another round of heat.
BAILEY1
2017 RAM 2500
Dat Cummins!
Glad to hear your retro has started, keep us updated. The only part I hated was removing the glue from the housing after I got the clear cover off. PITA!
R
RAMdriver
That glue is a PITA for sure. I've noticed that if I heat up the housing and then let it cool for a couple of minutes, the glue becomes hard enough and pliable enough to pull it out in big strips. It's just time consuming. I have about 3/4 of the glue out of the first housing.
R
RAMdriver
is there a how to on the hid harness install? I'm either doing it wrong or the ballasts are not working
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
sorry about the delay on the forum here, but nice chatting with you earlier!
