rotors
navigate66
slc
Are the rotor thickness the same on a 1500 and 2500?
N
navigate66
slc
the reason i'm asking is i did an upgrade on my brakes i put 97 2500 calipers on the front and put 96 1 ton wheel cylinders on the back. a 2500 master cylinder. did all my bench bleeding and bleeding of the brakes. I have no leaks but the pedal is soft and goes to the floor
Travelin Ram
I don’t see how rotor thickness could result in soft pedal or sinking.
Symptoms sound like:
Fluid leak. (Can be seen)
Air in system. (Often can be pumped to get a firmer pedal)
Faulty master cylinder/ internal bypass. (If pedal sinks under steady pressure after pumped up and no external leaks)
PS- doesn’t help you, but I recall trading off a 97 1500 because the brakes were so weak.
N
navigate66
slc
so when i put the new calipers and pads on there is about an inch or so of space between the pad and the rotor. so that's why i was wondering if the thickness of the rotors were different. I have no leaks that i can see and I've bled 2 pints of fluid through the system.
N
navigate66
slc
Idk what it is about the 97 1/2 ton but the brakes have never been all that good.
