Solohopper
I don't have experience with the 4.7, but with the hemi the PCM has two modes. When the engine is cold it runs in "open loop", meaning the fuel/ignition (AFR) is controlled by a internal table and the O2s has no input. When the engine reaches operating temp the mode changes to "close loop" with the O2s providing input (trim) to maintain the AFR to reflect this internal table that is constantly adapting to atmospheric and component changes (wear) within limits. If it is unable to adapt, then most often will generate a DTC. IMO, you do not have a cam/lifter problem.
What is DTC?
Any other ideas of what it may be if it's not the cam/lifter?
