Turnbilljr
I have a dodge 2001 ram 1500 5.9 gas Engine. It has a rough idle . Here is what I have done I have put spark plug wires spark plugs distributor cap rotor button new injectors new temperature sensor new intake temperature sensor Plenum gasket new timing chain and two new oxygen sensors upper and lower a new idle control valve and ignition Coil . I have check compression on all eight cylinders it averages out to be 160 pounds and I have also replaced the PCM. The only thing I haven’t changed would be the Crank sensor the distributor pick up coil And Catalytic converter. Any ideas would be highly appreciated
