Hey everyone
New guy to the forum here. I have a situation with my 2000 2500 5.9 gas. I got the truck about 4 months ago with what was thought to be a blown trans (turned out it wasnt) also it had misfire codes for cylinders 3 and 8 i believe. After further inspection i sae that the distributor ears for the cal were broken off. So i replaced the dist. cap, rotor, wires and plugs. I should say here that the #8 spark plug was so seized i took it out with a 1/2 inch breaker bar. I replaced the plenum gasket. Immediately upon starting the truck it ran rough at idle. Driving was ok but seemed to lack power and takes a while to fire up when hitting the key. 2 weeks ago it shot a check engine light the code is a P0305. I should also say that i went through all the sensors (map, IAC, throttle position...i replaced all but the map since it reads good on a scanner.
Can anyone help point me in the right direction? Maybe someone has had the same issues? Also the truck needs exhaust work...all of it, the y pipe is bad at the flanges and the muffler is shot.
Any info would be greatly appreciated!
