1- Rear window line is really soft. Compared to the crisp black line separating the window from the roof of the car on the front window, the rear window line is very dull. Would like to see the taillights tinted also.
2- Rear caliper is in the wrong place I think (pretty sure its on the forward side, but I could be wrong). The rear rotor is also bigger than it should be – usually the rear is smaller than the front. Nice work allowing the background to come through the side windows – this is overlooked a lot of times. The drivers side tint looks to be around 15% or so, but it doesn’t look like it matches on the passenger side. Maybe darken the passenger windows up a bit. I like the exhaust
3- Probably the simplest chop of them all, and very well done too. The only thing I found is under the rear window the black line should have been carried through to keep the two-tone straight.
4- Definitely the most detailed chop of the group. The background was left out of the passenger window it looks like. There should be more blue in it. Also, the rear wheel doesn’t look like its pointed straight (toe?). Possibly missing the passenger side hood pin also – not sure. Im not a fan of the upper background choice at all. It deters too much from the car itself. A simpler background would have been a better choice
5- The thing that sticks out the most to me is the rear wheel swirl. Not sure if the wrong tool was used or what, but the blur isn’t centered on the wheel, and it grabbed part of the body panel on front also. The whole car doesn’t fit the background very well – looks like the car is floating despite the shadow efforts on the ground. Nice work with the chally front end conversion
6- I would have liked to see the entire car bigger. Because its so far back its almost like you’re trying to hide minor blemishes (which I really don’t see any). It’s a nice background, but bring the car up a little bit and show it off. Kind of a pretty constant theme going on with all these chops – the background isn’t coming in the passenger window. Nice work with the srt wheels, but I think the caliper is placed wrong in the rear. I would have liked to see the two-tone line continue straight over the front fender instead of following the curve. Overall really nice work
7- umm. Holy crap that thing is beast lol. Looks like the drivers’ side tracks are tucked into the fenders too far. Drop them down a bit and it would look cleaner. Chances are you wouldn’t have tracks like this without a lift also, so drop those tracks down a bit. You also wouldn’t have to cover up as much of the side of the car. Theres a little hiccup on the roofline of the car and the lower portion of the window where you took out the C-pillar.
Hopefully everyone takes these as suggestions, not criticisms. Well done all around. Great job everyone
