Dodge96Ram
- Dec 6, 2013
- 618
- 141
- Location
- Long Island NY
- 1996
- Magnum 5.2
In the past few weeks I have done a bunch of work to my 96 ram. I had a bad plenum so I pulled the manifold and replaced the plenum with the aluminum pan. I also swapped over to a 98 kegger with no divider. I installed headers, new valve cover gaskets, new tranny cooler, ported throttle body, new radiator hoses, new fan clutch, and a new thermostat. I also replaced both temp sending units in the manifold. I filled it up with antifreeze and fired it up. It's getting to about 230* or so (right between 200-260 on the gauge) and sitting there at idle just in my driveway. The thermostat is opening, upper hose gets hot, radiator core gets hot, lower hose barely gets warm, the bottom passenger side of the radiator stays cool. Both heater core hoses get hot and I have heat. I pulled the hoses off the radiator and ran water through it and it flows freely, not blocked up. Put another thermostat in it just to do it, nothing changed. Pulled it all apart again and pulled the water pump off, blades look brand new. The only thing I do not have installed back on is the fan shroud purely so I could see if anything was leaking. I understand that may make it run a little hot however why is my lower hose and corner of my radiator staying cool? As soon as that thermostat opens water should flow plenty fast enough and stay hot enough for everything to be hot. I did try jacking the front passenger side up off the ground about 6"-8" or so just to see if I had an air bubble, nothing changed. I also unbolted the radiator with both hoses still connected and lifted the passenger side of it up pretty high to see if I had a bubble some how in the lower corner, nothing changed. What am I missing here!
