S&B CAI Scoop?
audio1der
Airdrie, Alberta
I installed the scoop at the same time as the CAI so I'm not sure.
I figured if it has the ability to add it, why not maximize the benefits??
URdone21
URdone21
CA
2013 Quad Cab
How was the install? Does it sit flush with the bumper or is it an inch or two higher?
audio1der
Airdrie, Alberta
It was a bit finicky getting it into position, but fits well once you do.
I'd say it's about 1.5" higher than the plastic chin under the bumper. It has a very large mouth/opening and the rectangular shaft between the mouth and the airbox is generous; it's a serious opportunity for more cool air to get at the filter & into the engine.
Here's a slightly different angle from when I installed my drain hose for the Moroso can.
URdone21
URdone21
CA
2013 Quad Cab
Is my truck able to take advantage of the extra air even though it has the factory throttle body?
URdone21
URdone21
CA
2013 Quad Cab
Can anyone answer my question above please?
MikeG
Livonia La.
I think if you plan on changing the throttle body it would be worth it.
audio1der
Airdrie, Alberta
That's a really tough question. Honestly, I noticed more of a difference after installing the CAI with scoop on the otherwise stock truck, than I did adding the ported TB afterwards. Can you ever have too much air? Nah. Can you do much else with $99? Nah, but I'm biased.
Orca
