THRobinson
- Apr 19, 2018
- 167
- 11
- Location
- Zurich, ON (Canada)
- 2003
- Hemi 5.7l
Still trying to sort out the startup/shutdown issue on my Dodge. Weather finally getting better here in Canada so, can start getting into it a bit more... I work outside in the yard so, -15 degrees and snow, not a great time to troubleshoot.
Anyways, long story short... I start the car, it runs perfectly fine for 2-3 seconds, then dies. No smoke, coughing, sputtering, nothing. Runs fine then shuts off as if I turned the key off.
Tried a few things, stuff from here and stuff from YouTube... one thing I read somewhere was that it could be the security. When it does die, there is the red LED light on the cluster that's on... no markings/words on it. Here's an image of it I found on Google, not my cluster but same thing.
LINK
Could it be starting, then a security issue shutting it off?
My last car was a 2002 Impala, and had numerous Passlock issues. Common issue with those Chev's 2000-2005. Friend had it, cost about $600CAD to fix, 2yrs later, happened again. I avoided that and got a reprogrammed ECU, which made the car run a bit better and guy was nice enough to program it to bypass Passlock errors. $100 permanent fix.
Could a similar thing be happening with the Dodge? On the Chev it wouldn't allow it to start at all. Not sure what/how the Dodge security works...
LINK
