- Nov 5, 2016
- 6,923
- 19,054
- Location
- Maine
- 2015
- Pentastar 3.6 V6
No code yet ! I'll stop at the dealer Monday,And order a lb. of KY lolAre there any stored codes?
Also I recommend instead of grease bring KY jelly since the bill will, most likely, be more than you expected.
It was not my reader but a friends ! I'll ask my regular mechanic next week when I go in for inspection!Can your code reader read tranny codes? Some can’t.
Yes the 8 speed dial ! Not in limp mode running fine !Do you have the ZF 8 speed? Wouldn't take it to the stealer just yet, is it in limp mode, you need a shop with a better scanner it may be a sensor, the brains on here can help you, how old is the fluid and filter, you got 93,000 on it, wonder if it's the rotary dial for the trans.
Is your trans acting ok ?Hope to update Wednesday after I leave the dealer ! I am thinking I will look like this Before Dealer visit (___*___) After Dealer visit (___O___)
Yes Transmission seems fine !Is your trans acting ok ?
