Sheared top of Strut post off - Bilstein Install
jcarden10
Raleigh, NC
2014 Big Horn
Well, as you can see in the photo I just sheared the top of my strut post off. Any suggestions?
Fanta1500
Albany NY
Have a box wrench for the nut? And can you get a small wrench around the base of the post?
jcarden10
jcarden10
Raleigh, NC
2014 Big Horn
Dont have any box end wrenches. I was able to get a regular open end wrench on it and used a socket on the top. If I could get the broken piece out of the socket I think I could put back on whats left, but it seems to be so locked up I don't know that it would do any good. My neighbor has an impact wrench that I'm gonna try in the morning. Hopefully that will work. If not, could I just drill it out since I'm replacing it anyway?
Fanta1500
Albany NY
Try impacting it for a good 45 seconds it should come free from the post
Fanta1500
Albany NY
Get it off any way possible honestly, just cause you aren't gonna re use it. Big thing for the bils when you get it off just make sure the washer goes on before the top mount, just in case you didn't know that already
jcarden10
jcarden10
Raleigh, NC
2014 Big Horn
I did read that in another post earlier today, but thanks for the reminder!
jcarden10
jcarden10
Raleigh, NC
2014 Big Horn
Maybe I'm missing something but how would I get a vice grip on the strut shaft
jcarden10
jcarden10
Raleigh, NC
2014 Big Horn
Just the impact isnt working
WilliamS
Tampa FL
vice grips on the shaft, reach through the spring to get to it, make it tight. You know thats sounding wrong in my head. Anyways vice grip the shaft, and impact it off. Its going to work if you have a good grip and a good impact.
jcarden10
jcarden10
Raleigh, NC
2014 Big Horn
I dont see a way to get to the shaft
LB3711
Trumbull, CT
3.6L V6
just move the inner plastic shroud out of the way
jcarden10
jcarden10
Raleigh, NC
2014 Big Horn
How? I can only move up or down so much
Backwoods
I would just drill the nut out, then once you feel like you have drilled through enough take a large punch or chisel and break it off the rest of the way. Kinda like a giant rivet. its all getting replaced. Might take a little while to do.
jcarden10
jcarden10
Raleigh, NC
2014 Big Horn
Well I drilled the top half of the nut out and hit with the impact, came off in one hit. Shouldve done that hours ago.
Now how do I get the lower spring seat off? This thing on the top of the shock is in the way. Is it supposed to come off?
jcarden10
jcarden10
Raleigh, NC
2014 Big Horn
Forgot the pic
jcarden10
jcarden10
Raleigh, NC
2014 Big Horn
Nevermind. I didnt hit it hard enough
lharrell79
This is why I love working on trucks. Every 2 hour job ends up a 48 hour job. :roflsquared:
Marciel
Struts are cheap just buy new ones.
Sent from my VS835 using Tapatalk
