Should i get this 03 Dodge 2500 QC LB 4x4 turbo diesel?
Discussion in '5.9 Common Rail' started by zodeac13, Feb 11, 2015.
  1. zodeac13
    zodeac13 Junior Member
    Feb 10, 2015
    Ram Year:
    2003
    Engine:
    5.9 Litter Diesel
    I am looking at a '03 2500 turbo diesel and was wondering if it has any major problems. At least for that generation or year specifically. Anything i should look for or feel for while test driving. It has ....
    - 5.9L 24v Turbo Diesel
    -163k M
    - AT Tires
    - Single stack exhaust
    Everything else looks stock, im not to sure and this is my first "Truck" truck. along with that i was wondering was would be the best tuner for MPGs.
  2. DannyMK2
    DannyMK2 Senior Member
    29
    1,724
    471
    Mar 25, 2013
    Long Island, NY
    Ram Year:
    2015 Power Wagon
    Engine:
    check for unusual smoking. a puff of black when its started or under hard acceleration is normal. huge black clouds are not. some goes for white/grey smoke. you might see a little for a few seconds when its first started in the cold, but any decent clouds or white smoke when driving is not good. check for blow by. make sure the trans shifts good and holds lockup (assuming its auto). oil pans are known to rot and leak, make sure its in good shape. smell the oil for diesel. check the front end for play. other then that look it over like you would any other car or truck.
Share This Page
