Should my AC condenser efan be running ALL the time?
FSUNole17
So I turned on my truck yesterday from sitting over night, AC off, and the efan starts running. Why would this be, is this how it is supposed to work? If not, do I just need to take it to a Dodge dealer and ask them to check it out??
F
FSUNole17
All AC or defrost or heating fans were in the off position.
F
FSUNole17
I guess trying to get an answer to my original question, SHOULD it be running all the time or no?
Robstar
I have the same situation on my 07 hemi. When I start it cold with everything off it will be on and be super loud! It usually ends up turning off after it runs for a few minutes but its super annoying.
F
FSUNole17
I am wanting to take this to the dealer to get fixed, but is there anyway for me to troubleshoot it myself without taking it in? What would I need to look at that the dealer would check?
S2kiHemi
Houston TX
AC fan shouldn't come on when you start the truck. Try disconnecting the battery for 30min and see if that does anything.
Mr_Nacho
Saluda, S.C.
My 06 has done this since I got it '08, it does seem odd and can be annoying.
F
FSUNole17
I don't know how to reset the PCM, I am going to unplug the battery for 30 min tomorrow and see what that does. I believe the only downside to this is load on the charging system when it shouldnt be on as well as premature wearing out of the fan motor, correct?
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
check fuse #23 and see if it says pcm...if so, pull it, and put key in ignition an turn to start position (it won't crank) and hold there til all the dings disappear (snap seat belt on to lessen the dings)...listen for a ding, it will pause for about 3 seconds, then a confirming ding..that indicates the pcm reset.
F
FSUNole17
Great, thanks! I will give it a shot and see what happens
fasteddy0150
