Merc225hp
The drop pitman arm will correct the steering linkage angle for the small lift you have. You would look for a 3" drop pitman arm.
Pull the rear diff cover draining the oil and look for metal bits/shavings, pull the rear drive shaft and check the u joints for binding or slop, grab the tail shaft housing of the xcase and see how much it moves, it will a little but should be no more than 1/2 inch anyway moved.
