Sometimes no start
Randy6666
Va
6.7 diesel
2007 2500 6.7 diesel 170000 miles auto transmission
Every once in a while it won’t start. Seems to happen after its run for awhile and is shut off to run into store
Etc.
no clicking no nothing. After a few rotation of the key it will start back up. Truck runs fine no other issues at all
Ignition switch going bad maybe
Batteries are good.
Thanks for the help
Stay safe
Snake15eyes1998
USA
Do the lights on the dashboard come on as normal? When this happens?
R
Randy6666
Va
6.7 diesel
No they don’t snake eyes
BadHemi2014
Greater Cincinnati area
I'm sure you've done this, but double check your battery cables. We had similar issues with our dually and almost started down a rabbit hole luckily I went to test the battery and realized duh, these are loose.
Karlsweg
SW Florida
Grounding issue. Check and clean all you can find and coat with white lithium grease.
