Spark plug/heat shield removal?
RebelRam01
New York
Magnum 5.9
Anyone have any tips for removing the heat shields to get to my spark plugs in my 5.9 magnum? They are due for replacement and the shields have shrunk from the heat and I can not get the socket down in to remove them. I have pulled one out so far after fighting with it for hours, they do not just "pull out" and whoever thinks they so isn't running on all cylinders. I am going to try grinding down a socket next to see if it fits, just from a video I saw. I can not fight with each one of these heat shields, I'll never be able to remove the back four by the distributor. I don't want to take this to a shop just for spark plugs because they would charge me for just the time spent taking these damn shields off. If anyone has any advice it would be appreciated!!
G-Ride990
Administrator
Administrator
Chandler, AZ
Best way I found was to grab one right at the split with some needle nose vise grips. Twist the vise grip towards the gap and pull.
If they are stuck you may want to soak them with penetrating oil. I never had any issues getting mine out on my 5.9 Dakota.
I bet you could use a slide hammer on them if you have one in your tool box. That would probably work for the ones that face toward the front of the truck.
safetyfast
1996 Laramie SLT 4x4 Club Cab
I pulled mine with vice grips too. The bad news is that I had two plugs so rusted in that they broke off and I had a terrible time getting them out. Hope yours aren’t.
dapepper9
Iowa/Nebraska Border
5.9L V8
I find it easier to use a long flathead screwdriver and a hammer. Tap the flathead in beteen the head and the shield all the way around and bend it in. They practically fall out and no yanking on junk
ouch1011
Magnum 5.2
I've never had an issue removing them and i honestly have no idea howhthey would shrink. They are made of metal. Anyway, soaking them with a good penetrating oil like PB Blaster (not wd40) should help. If all else fails, bust out the torch.
RebelRam01
RebelRam01
New York
Magnum 5.9
Something about the heat from the engine block..i have read numerous articles where it warps them and shrinks them and I guess magnums are known for it. I don't think a torch around spark plugs would be a good idea.
mikeymopar
2002 3/4T
5.9L
I know it's a bit of an old thread but wanted to praise your technique. Some PB Blaster for an hour, 15 minutes of pounding the circumference of the boot at the block (especially crushing the area at the slit making it smaller), and then a couple minutes of wiggling, it pulled out. Thanks!
Reactions: Mop
dapepper9
5.9L V8
Thanks man! lol
Reactions: Mop
BrandonOG59
Darien wi
Now I know this thread is a bit old but this was one of the first ones that popped up when I looked it up so my tips to anyone would be use some wd40 or pb blaster let sit for awhile then scrap all the rust around it then take a air hammer next to the slit and keep going in until you see the heat shield moving then just wiggle and pull it out with some Chanel locks or vice grips comes out easy had at least half out of the 8 come out no problem.
Reactions: Mop
