Spark plug wire advice
JPT
NY
2015 Big Horn
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I'm shopping for new wires, was wondering if anyone had advice or experience with these.
What is the difference between these?
Taylor Spriro Pro 8mm
https://www.moes-performance.com/mobile/Product.aspx?ProductCode=72026
Taylor Thunder Volt 8.2mm
https://www.moes-performance.com/mobile/Product.aspx?ProductCode=82026
I would recommend you search for threads about hard starting when cold. They seem to break down under extreme load condition and I have no idea why. Some crate engines come with shorty's but don't know what brands are used or availabilty. If you want to get rid of the waste spark wire you can upgrade to the 6.1 dual coils. Kits are expensive and available. Or get the coils and electrical plugs from a pick and pull. You will also have to change to the newer valve covers.
Harley Harrold
USAF Ret. 36+ years service
Mississippi
5.7L HEMI
I have read that a lot of people, who switched to the shorties, had problems with them in the winter, causing them to reinstall the original type plug wires.
StaLL1oN
StaLL1oN
Arkansas
2003 1500 Quad cab SLT 4x4
Alright looks like I'll go with the msd blaster coils or whatever it was moes sells for the 03
ATXHEMI
Round Rock Tx
Your truck has spark plug wires??? My 2003 is coil on plug design...
Your coil only sits over 1 spark plug. There is a wire that goes to a plug on the opposite side.
ATXHEMI
Round Rock Tx
Don't waste your money on the MSD coils. The fastest trucks on these forums are still running stock coils.
ATXHEMI
Round Rock Tx
If you want to upgrade get 06+ VC and coils. This will eliminate the cross over wires.
Redtruck-VA
Virginia
Will I need the newer valve covers to run the 06+ coils Red?
Yes, plus the newer electrical plugs. These can be from a pick and pull, repair pigtails or there is adapters that are plug and play.
StaLL1oN
StaLL1oN
Arkansas
Shot you a pm
reyzapien88
