Splitting front dif to drop oil pan? 2014 1500 4x4
cwalker12
Canada
I know that everyone recommends dropping to dif to get the oil pan out on the 4x4 models....but has anyone just pulled the axel and split the dif. I looks like if I can get that passanger side housing off the dif I should have enough room to drop the pan. splitting the dif is as simple as taking 4 bolts out. From what I can see on youtube that piece of the dif should just slide off and back on without any issue (vid link below, watch from :30 - 1:30).
Has anyone tried this before? Am I seeing clearance were there is no clearance? Is the pan gonna get hung up on something Im just not seeing?
OC455
Central NY
Maybe check this out before tearing apart your front differential....
Orca
