Stalling issues with my 04 ram 1500 5.7
Mooseknuckle00
Akron ohio
I have an 04 ram 1500 with the 5.7 hemi it ran fine till the gas light came on one day I stopped got gas it sputtered like it was going to stall while pumping gas a time or 2 but didn't I made it 2 exits on 76 it started bucking and sputtering like it was out of gas pulled over and it stalled it'll fire up every single time but die immediately I can now get the truck to idle fine but stalls when you give it gas most of the time sometimes you can rev it up but starts
M
Mooseknuckle00
Akron ohio
Misfiring really bad around 2500 rpms can't pull it's own weight can 02 sensor cause this
jws123
nj
Check fuel pressure when its running sounds like a failing fuel pump did you scan the truck for codes? also lol if im reading right you fill the truck while its running? dont do that lmao.
Smokeybear01
US-NW Coast
Cummins 5.9
Yeah, second that. Don't fuel with the rig running. You either have a failing fuel pump or plugged fuel filter. It's showing all the signs of an engine starving for fuel.
