Starting my new build
VegasDragger45
I started wiring my truck for it's new stereo. I've listed the components below.
CT-Sounds everything
Single 10" Strato V2 Dual 4
AT500.1d
at60.4
Meso 6.5" comps
Tropo 6.5" rear
3 - 17' White rca's
SkyHigh speaker wire
and a box from NetAudio and a set of there speaker adaptors
Finished running all of the speaker wire yesterday. Wasn't to bad the worst was the drivers side door.
VegasDragger45
VegasDragger45
The rest of my components just came in
60.4
6'5" Meso comps for the front
6.5" Tropos for the rear doors
and finally 3 - 17' white rca's
Toeknee
Price for entire build??????????
moregrip
looks awesome brother! Please post updated pics!
VegasDragger45
VegasDragger45
Thanks all, these rcas are sexy I hate that they'll be under the carpet. My box should be here next week with my speaker adapters so I can get it all done then get it tunned
DRkNESS
South Jersey
When you say " your box " what size subs and how many will you be running ? I'm only going with a 10" and am looking just to add hopefully a Fox box. Will you be running passive or active ?
VegasDragger45
VegasDragger45
I'm going with 1 10" ct-sounds Strato v2 dual 4ohm
I had the fox box with amp rack and loved it just wanted a bigger amp rack so I got the single sub box with amp rack from NetAudio
DRkNESS
South Jersey
Netaudio, is there a link for exactly which box that you are referring to please ?
VegasDragger45
VegasDragger45
Open up the rcas and laid them out to uncoil before install. These things are beefy
Etroze86
Grand Forks ND
Nice they remind me of the Stinger 8000 series
Sent from my SM-G920V using Tapatalk
VegasDragger45
VegasDragger45
I agree, I had the 6000 series before this. Finished running all my wires today except I can't figure out where to get a good ground
Used a little zip tie truck I learned to keep the wires organized
Etroze86
Grand Forks ND
I'm going to make my own, might tech flex them but might not. Nice zip tie trick.
DRkNESS
South Jersey
In my one build all is is techflexed, for this next one not so much lol..
RedFalcon
Katy, TX
Very nice trick with the zip ties. I'm sitting here staring at it but I still can't figure out exactly what you did...
