Starts but won't go in gear?
Discussion in 'Tech Info' started by allen shores, May 25, 2013.
  1. allen shores
    allen shores Junior Member
    54
    May 25, 2013
    Rockton IL
    Ram Year:
    2002
    Engine:
    4.7
    New to forum, looking for some help. Truck starts, but then won't go in gear. After several tries (turning key off, and starting again) it then goes into gear, but if put back into park it won't go into gear again. Note blower motor would not work right before this happened, but works now. Any ideas. Thanks in advance.
  2. badblackram06
    badblackram06 Senior Member
    31
    441
    36
    Jun 30, 2010
    MS
    Ram Year:
    2006
    Engine:
    4.7
    Sounds like the ignition switch is going bad.
    Welcome to the forum!
  3. allen shores
    54
    May 25, 2013
    Rockton IL
    Ram Year:
    2002
    Engine:
    4.7
    Thanks. I did find another post where this was the problem and I printed the fix. Just seeing if that is what others thought was the problem.
  4. badblackram06
    31
    441
    36
    Jun 30, 2010
    MS
    Ram Year:
    2006
    Engine:
    4.7
    It could also be the brake shift interlock solenoid on top of the ignition issue
  5. allen shores
    54
    May 25, 2013
    Rockton IL
    Ram Year:
    2002
    Engine:
    4.7
    Where is that located?
  6. allen shores
    54
    May 25, 2013
    Rockton IL
    Ram Year:
    2002
    Engine:
    4.7
    Anybody have a part # for ignition switch? 2002 4.7L
  7. BAILEY1
    BAILEY1 Senior Member
    4,906
    484
    Dec 21, 2012
    St Tammany Parish, LA.
    Ram Year:
    2017 RAM 2500
    Engine:
    Dat Cummins!
    I was going to say brake switch also.
  8. allen shores
    54
    May 25, 2013
    Rockton IL
    Ram Year:
    2002
    Engine:
    4.7
    The brake switch seems ok, I'm leaning more to the ignition switch.
  9. BAILEY1
    4,906
    484
    Dec 21, 2012
    Ram Year:
    2017 RAM 2500
    Engine:
    Dat Cummins!
  10. badblackram06
    31
    441
    36
    Jun 30, 2010
    MS
    Ram Year:
    2006
    Engine:
    4.7
    The interlock solenoid is on the steering column. It's what unlocks when you press the brake pedal if I'm not mistaken. Normally you would hear a click noise inside the column when you press the brakes.
    I would swap out the ignition first. Then go from there.
    BAILEY1 likes this.
Share This Page
