88ROOK
Before i call JL Audio I'm wondering if anyone else has had this problem. I'M experiencing alot of static through the speakers. if i turn the gains down on the amps it still comes through, but if i turn the gains up the static gets louder. Now this is with the HU volume all the way down also. wierd thing is it comes from the right front and the left rear and both fronts and rears are on different amps. the static noise does not get louder when i turn up the volume, I'm sure its still there but obviously the music is drowning it out as the volume goes up. Only thing i can think of is using cheap Y adaptors to the DSL could cause this as I'm using high quality rca wires from the amp to that point. any help would be appreciated
