stocker death wobble
Discussion in 'P Pump' started by ram15, Feb 19, 2014.
  1. ram15
    ram15 Senior Member
    24
    144
    Oct 23, 2011
    Mendocino, Ca
    Ram Year:
    1999
    Engine:
    5.9
    I got my new 96 cummins from my dad and he said hes had death wobble issuses but he installed a steering stablizer and pretty much got rid of it. I just hit a bump goin down the road and the entire truck started shaking a lot. It was to tge point where it was hard to steer. What could the reason of this be on a stock truck. Thanks
  2. autokraftgt
    autokraftgt Senior Member
    971
    328
    Mar 28, 2013
    Ram Year:
    Engine:
    Hemi 6.1
    Few things can cause this...check your king pins for play
    check your tie rod ends
    check your steering box to see its functioning properly
    Stock size tires? Larger tires are more prone to wobble
  3. Wandell
    Wandell Senior Member
    958
    253
    Oct 2, 2012
    Ram Year:
    Engine:
    Cummins 6.7
    Usually death wobble is caused by one or more worn steering components. If a 1996 front end has never been rebuilt, everything could be (probably is) worn out. Also, a lot of times a steering stabilizer just masks the problem.
  4. smokedya
    smokedya Member
    87
    Jan 20, 2014
    Ram Year:
    2007 1500 sport
    Engine:
    Weird my buddies wifes 2006 2500 diesel has the dodge death shake as well.
  5. ram15
    ram15 Senior Member
    24
    144
    Oct 23, 2011
    Mendocino, Ca
    Ram Year:
    1999
    Engine:
    5.9
    I was reading one of the main problems could be the track bar or track bar bushings. Am i able to tell just by play how bad the bushings are?
Share This Page
