ramitwithmydodge
- Mar 10, 2014
- 19
- 1
- 1998
- Magnum 318
Alright so one thing you want to make sure of it that the radio you purchased has a standalone sub preamp output. Most radio do nowadays with the thrive of everyone and their mom wanting to add subs to their vehicle. A good voltage of a preamp output in around 3v you should be fine with for just a sub. If you were going to look into doing a 4 channel as well I would highly suggest a 5v preamp voltage. More signal voltage going into the amp in always better (cleaner sound). Now most bottom end radios with a sub/rear output are going to be right around 1 or 2 volts. Will the subs work? Yes, just won't be as clean of a sound with a higher voltage head unit. Do not get a bazooka tube they are complete junk. I can't tell you how many of those I have installed for the "cheap" customer and they have been nothing but displeased with them, despite me telling them prior to install exactly what they were going to get. Kicker makes good subs, I have always dealt with them and they have yet to disappoint. JL makes great speakers as well I have nothing against them. To be honest I would have to say they really pay attention to their amps. Their amps are rock solid much like kicker's. I don't know how much you are willing to spend because there are higher price brackets that of course offer better better sound quality amps but that isn't another post. Let me know if you want to hear about them and I can go into detail on those brands as well.
Bottom line if you are just going to be doing a sub I would look for a mono block amplifier. They are more geared towards subs as far as low pass filters and adjustments on the side whereas most 2 channel amplifiers can be used to power a pair of door speakers or flip a switch and it cuts out the higher frequencies to be able to run subs.
Sent from my cellular device
