Suspension Lift with Leveling Springs
RetiredBCDanny
Central Florida
Good am I had a 4 inch RC suspension lift installed but the front sat 2 inches lower vs the back, had new spring's installed in the front with the front now 1 inch higher, what options do I have to raise the back end up an inch to level the truck?
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Reach out to @Nick@GotExhaust he can order you a zone rear box kit with the 3” coil option. It will come with the coil springs and all brackets necessary To install properly
Nick@GotExhaust
Preferred Vendor
SC
The zone rear box kit is a great way to fix this. It comes with everything you need. I would recommend going with the Fox rear shocks made for it too! Send me a message if you would like a quote
TestPilot57
Vermont
Good am I had a 4 inch RC suspension lift installed but the front sat 2 inches lower vs the back...
This is typical stock raked setup, to allow for adding max rated payload and have the truck not look like it's overloaded. Meaning that, if you level it, whenever you put more than groceries in the back it's going to look overloaded...
OasisNinjaBat
