crazykid1994
Was just looking to purchase a rp 20-820 filter from summit. No longer available??? Just messaged nick at got to see if he has some. Anyone have a clue? Royal purple website also not pulling up for me
I jus run what came.
Syn mobil one however i ONLY use a good syn filter
KnN, Royal P. Bout 12/13 dollars.
I think there is a cheaper one made by fram but still full syn.
Change bout every 7 unless i tow a lot then 5.
Now, i use nothing but amsoil tran fluid every 35.
Couldn't believe the shifting diff between the 2 oils. Stock/HD Amsoil.
Wow no kiding? 10 thou?35,000 OCI on the trans is way more proactive than most truck owners. Good on you sir. If you can, try and shorten it more. RFE’s are awfully particular about staying clean. It had been recommended by trany rebuild shops to do at least fluid changes every 10,000. I know its crazy sounding. But its true.
Im on a plan to do fluid every year and fliters every other.
Just trying to help sir.
**** i was bout to cry when i found out i should do it at 35. But i got a question maybe yiu can help wit.
Im almost due for that fluid change in 5 thou. It'll be the 3rd time. 2 times Pryor we used a flush then conditioner. Mind you this is just a flush, not a filter change. Should i go ahead and get filter swap also are is it needed beimg i flush and have bn relatively good about changing the stuff...
Cool, and the RP filters are on shelves, too, right? Less important since you only need them every/every other change, but it's still more convenient.5w30 in whatever is on the top of this poll, m1 or PP can't go wrong.
Being the spin on filter is paper media..... i would change it. JMO. Some guys are comfortable with 30,000 on filters. Burla cut his open after 8 years but i can not remember the miles he had on it. Don’t even want to guess but I do remember him talking about how the paper media was extremely stiff and in poor shape. He puts very little miles on the truck as it’s just a work truck for him. Not necessary a DD.
Burla?
That said, id change it. On the same note. If you’ve been following the original synthetic oil thread we have been discussing for quite some time now (on and off) .... we have the ability to run high quality synthetic media engine oil filters in place of the paper OEM filter. If you’re interested in using something other than OEM we can talk about that but if you just want to use OEM filters which is perfectly acceptable I would change them every other year or so. Im mean, it is just paper filtering Oil that faces drastic temperature change every time you drive it.
There honestly is not much wrong with paper filters, they get the job done fairly well.....BUT they do not last very long AT ALL.
You using a “flush” additive? If you are doing something like that then absolutely change the filters.
Sorry I’ve got to cut it short got to get back to work.
Not sure we on same page. I was talking about transmission. I was asking if the pan filter should be changed out. Iv been using a cleanser then an additive with new fluid every 30/35 thou.Being the spin on filter is paper media..... i would change it. JMO. Some guys are comfortable with 30,000 on filters. Burla cut his open after 8 years but i can not remember the miles he had on it. Don’t even want to guess but I do remember him talking about how the paper media was extremely stiff and in poor shape. He puts very little miles on the truck as it’s just a work truck for him. Not necessary a DD.
Burla?
Assuming you’re talking about and RFE transmissionNot sure we on same page. I was talking about transmission. I was asking if the pan filter should be changed out. Iv been using a cleanser then an additive with new fluid every 30/35 thou.
Well I'll be dang, i had no idea about the spin on filter and the sump! Guess thats what got me confused. No one has ever said a word about that to me till now. Thing is, i been under that truck lots and times and seen nothing that resembles a spin on filter.Assuming you’re talking about and RFE transmission
If you’re using a cleaner in your transmission I would change the filters (plural) every time.
The transmission also has a spin on filter just like your engine. Has the sump filter like you’re talking about that has a felt, but also has a spin on.
We are talking about the same thing.
The felt filter will outlast the OEM paper filter guaranteed but if you’re in there changing the spin on paper filter then you might as well change the sump filter to.
Like Mike said the paper sucks ass. You’re welcome to run it but it’s not what we will do.
2012 ram 1500 4x4 6 speed ??
As far as it being RFE!
Not a clue..
Here's pics of the spin on and sump filter when I changed mine on my 65RFE 6 Speed Xsmn .Well I'll be dang, i had no idea about the spin on filter and the sump! Guess thats what got me confused. No one has ever said a word about that to me till now. Thing is, i been under that truck lots and times and seen nothing that resembles a spin on filter.
Not a clue..
I got cha!!The spin-on filter is inside the transmission oil pan.
