Witch
- May 6, 2016
- 1,295
- 630
- 2015
- Hemi 5.7 liter
Thank you gentlemen,is there a specific weight that is better than another ?
For warranty purposes, stick with a 5w20...Thank you gentlemen,is there a specific weight that is better than another ?
Welcome to the forum Sir ! Read lots , post lots and help others when you can !I am new at this
never changed oil before
Saw a video of the oil change places ripping off people so i am going out and getting the stuff I need to do it myself. I am not trusting my new truck to those clowns
What brand & weight is best for a 5.7 liter Hemi engine, with CAI, low resistance exhaust and Hemifever tuned ? Also is there a specific filter that preforms better than any other ? or is a filter a filter ?
Thanks for any help,it is appreciated
stick with one of the bransd that are in the "poll" at the top of this page with the addition of a few other that are well respected...
Pennzoil Ultra Platinum ( or just the "Ultra")
Red Line
this thread is FULL of info to lead you in the right direction. start reading. I was in the same spot as you and I am just taking the safe route and sticking with the "PUP" recommended by the manufacturer for now. it can be had on Amazon for a very reasonable price.
PAO vs Group 3
Based on the white paper published by Machinery Lubrication, recently posted, seems like the automotive industry is concentrating on group 3 & not group 4.
Comparing viscosity index (VI), Amsoil SS which is group 4 PAO vs PP group 3 GTL & QSUD group 3 in 5w20 grade.
Higher VI is better.
Amsoil SS: 152
PP: 158
QSUD: 168
Amsoil XL: 151
Amsoil OE: 150
Note, data extracted directly from oil suppliers published data
Red Line
If your worried about a possible future warranty issue don't use what the highest number of people here polled are using, the mobile1 because it does not meet nor does it have Chryslers required MS6395 rating, neither does Redline if you want to be positively safe use Pennzoil in any type, yellow bottle, gold syn blend, platinum or ultra full syn oils . this is the preferred ram oil and carries all the required ratings,
Pennsoil Syn 10/30 for desert heat works well.
It might work great and you may never have a issue but its not a viscosity that is listed as can be used, so if you had a oil related failure you could find yourself footing the bill. Manual is clear, 5.7 hemi 5-20 also says 5-30 can be used, no others are listed.
Guys on BITOG were talking about Amsoil. Thought this was a great post about botique oils.
See below. Thought this was a good point on the subject. Feel free to comment.
The strategic problem that the specialty blenders have is that the "specialty blends" no longer offer better performance than the commercial products they're supposed to be better than.
In engine oils, the specialty products are as good as the latest spec consumer products on the parameters that matter, surpassing the consumer blends only on parameters that don't make much difference in an engine. Gear oils are the same. Modern OEM gear oils today have better base stocks and additive packages than the specialty blends that were designed to compete with the old technology OEM products from two decades ago.
The specialty products that were vastly better than the 1990's OEM oils are no match for the 2016 factory products. The specialty blending community isn't fighting for market share any more - it's fighting to remain relevant.
I have to say that is a very good post and pretty spot on with the current oil market and the boutique brands like Amsoil, Redline and Royal Purple.
They are more selling a perception and feeling rather than an appreciable result of superior permance. Exceeding the limits of a specification does not always equate to "better". Nor is there a sliding 1:1 scale of better quality in relation to the premium price command by many of these boutique oils.
Staying relevant is good observation that I am certain the fan boys of a particular brand will have problems with to justify the higher cost they pay.
RL 5w30 is available at most WM outlets.
There should be a regulation to have all engine oil suppliers to furnish the twenty four ASTM test procedure results required to obtain the API certification and donut symbol, especially the all important sequence IV, 100 hour wear test procedure on an a actual test engine requiring a tear down.
The four ball test results published by Amway oil gives some measure of wear, but this test procedure is actually designed more for gear oil rather than engine oil.
Tire manufactures are required to imbossed the thread wear rating, wet traction rating & temperature rating on the tire. Europe also requires a rolling resistance rating imbossed on the tire, USA is working on this requirement.
However, use Amsoil products in power sports vehicles, vintage vehicles, lawn mower & generators because the SJ rating is available in synthetic.
Use Shell SN rated products in 5.7 RAM.
