Well thanks for doing all that, I'm sure you can see the benefit. That oil is at the end of it's life at 10k, your additives are great but your tbn is as low as I would want before I changed it. This wear is the wear pattern I have seen in every hemi no matter what the oil, and I have been a little stumped on it. I thought the film strength of redline would lower it, I was clearly wrong on that. I believe it is the 5w20 we are using, and I believe if you ran 5w30 of the same oil the wear numbers would be less, but of course we have to deal with the mds requirement. The good and bad news is you know your change interval and it is lower then I would expect at 10k. I am convinced these 25k oil change interval oils wont do that in these 4 gen Hemi's.
I have read over 10 UOA's and they all show similar wear. I have researched Redline a lot, that is what brought me to it, but I think we have a harsh condition that no oil is going to perform like it does in other none hemi engine. I know many people will shrug that statement, but I can only comment on what I've been seeing. One thing you might consider is trying Amsoil for a run and see if it comes up similar. Since you already have changed it, it is worth it to do another uoa and change it at 10k again. Bottom line is we need to address these wear numbers together and find solutions, or we are going to all be replacing engines sooner then we should. I don't think having any oil for a shorter OCI will change these wear numbers, the excessive wear is not a product of the oil, it is definitely the engine. So if you ran a conventional oil for 3 months you would have less wear numbers, but if you added it up all the changes to get to 10k miles and your one oil change 10k miles, the wear numbers would be similar. So you have a solid 10k mile oil, but you me and the rest of the people reading should try and see if there isn't something we can do to cut those numbers in half. It may be break in like blackstone said, but I have a feeling we just has a lot of soft metal and our oil is too thin. We need someone to try 5w30 for a similar run to prove me wrong. I will gladly do it but as ya'll know I'm testing this current second redline run as well, so it will be a while.
Curious how long as in months it was in your engine? How many miles on the truck? Was your truck ticking bad prior or just average? You run a catch can?
