Synthetic Oil
Oil of Choice
  • Castrol Syntec/Edge
    Votes: 236 8.5%
  • Royal Purple
    Votes: 327 11.8%
  • AMSOil
    Votes: 400 14.4%
  • Valvoline Synpower
    Votes: 160 5.8%
  • Mobil 1
    Votes: 994 35.8%
  • Other
    Votes: 662 23.8%
  • Total voters
    2,779
R.L.K.
Bristol , Tn.
How did you do that ?
R.L.K.
Bristol , Tn.
Damn I tried to quote you ...no workie
Hemi395
Cape Cod MA
Tap the post to highlight it, then tap the left arrow at the top right. This wasn't working yesterday for me so they must've fixed something either on the site or Tapatalk...
R.L.K.
Bristol , Tn.
That has worked for me once yesterday when I quoted Rampant , but then it stopped working ....I'm trying it again Now ..
R.L.K.
Bristol , Tn.
Nope , didn't work this time
Frustrating
indept
South Jersey
powdered eggs powdered milk, problem solved. They are better then you think if you never tried them, not like powdered mash potatoes, those I hate.
I know what you mean, I'm a fan of powdered water
Reactions: U&A
R.L.K.
Bristol , Tn.
Just noticed I can't send PM'S anymore ....jeeeezzz I hope they get this **** fixed soon .
I can't quote ( most of the times ) I can't send private messages my profile is all jacked up and doesn't even show what year Ram you have or Engine and I have 36 freaking trophy points ...whatever the hell means LOL
U&A
2016 3500 SRW
6.4 HEMI
@U&A , Good looking Kid there
too bad he's gonna take his prom date out on your out dated hand-me-down cool ass peddling bike !![emoji16][emoji16][emoji16][emoji44]
LOL
Thank you sir, my pride and joy that boy is. Hes a real lady’s man already. 2years old and is already showing off when they are around and holding their hands.. LOL
And he will get mamas jeep by the time he is in high school. She is going to get an unlimited in about 1-2 years from now. At least that is the plan.
Burla
2010 Hemi Reg Cab 4x4
So I found something that made this a little better, there is a function of ram forum dark or light, the light seams to make the forum semi usable, but generally still hate this ****. The people that are running stuff everywhere don't know how to improve upon things so they just end up f'ing up a good thing. The old Ram forum was the best forum software I ever took part of. Apparently the owner here said it was a security issue, I can accept that, but why not find something better then this? If I owned this I would be paying my minions to make it like it was before. This is like a blog or something very bland and not a good use of page space.
Burla
So to go back and explain one time what is going on with hemmerhead's test, I never doubted the results, just how that relates to an engine. VII's have good and poor qualities, the VII's are great as long as the polymeric bonds are in tact. However, we know with engine usage the polymeric bonds are broken, and when the vii's chain is broken those molecules just sit in the oil and are not as good as lubricating as base oils are, thus you can get engine tick or more metal to metal wear.
Rats latest test, Amsoils number 2 and 3 in his test, and believe it or not Prolong with qsud has less psi to fail then Amsoils, this is crazy folks, that is not group 3 oil at work, the reason wny Amsoil SS has the top two spots is because Rats test only heats the oil, he does not run it through an engine. it is no coincidence Amsoil SS did so well in a heated test and that 20 and 30 weight are on the top of the list, it is also no coincidence so many guys engines are ticking on Amsoil, what would be coincidence is if the engine is ticking right away with Amsoil, because if my theory is correct, it should take a while before the ticking should start because in the beginning of a run those VII"s will be be bonded together, and as long as they remain bonded together, then VII's lubricate better then base oil, or in other words it would take more psi before fail for the VII's in base oil, then just base oil by itself.
Some engines will tick right away, in those cases it is the defect ticking not the lubrication. But I am talking about comparing oils. it is also true that Amsoil might fix a tick that another oil wouldn't, because the VII's lubricate better when polymerized, but I wouldn't expect that to be a long term solution, because in those engines the tight clearances or the rubbing parts will likely shred those VII's.
You will not be getting a NOACK in the 6's for low weight group 3 base oils. That is the VII's talking to you.
This from some of they people who sell VII's.
Thickeners and viscosity index improvers are polymeric, and are added to reduce lubricant viscosity changes at high and low temperatures.
Mineral oil lubricants become less effective at high temperatures because heat reduces their viscosity and film-forming ability. The traditional solution to this problem was to make seasonal oil changes in some applications. With the advent of viscosity index improvers, that’s no longer necessary or desirable.
When viscosity index improvers are added to low-viscosity oils, they effectively thicken the oil as temperature increases. This means the lubricating effect of mineral oils can be extended across a wider temperature range.
When creating a viscosity index improver, a balance between the thickening efficiency and shear stability of the polymer is important. Higher molecular weight polymers make better thickeners, but tend to have less resistance to mechanical shear. Lower molecular weight polymers are more shear resistant, but do not improve viscosity as effectively at higher temperatures and must be used in larger quantities.
Polymer additives can also undergo thermal and oxidative degradation, unzipping back to smaller monomers, which reduces their effect. The highest possible degree of thermal and oxidative stability is desirable in addition to the features described above.
Afton Chemical's family of viscosity index improvers is primarily used in multigrade engine oils, gear oils, automatic transmission fluids, power steering fluids, greases, and some hydraulic fluids.
Ramnewbie
Rats latest test, Amsoils number 2 and 3 in his test, and believe it or not Prolong with qsud has less psi to fail then Amsoils, this is crazy folks, that is not group 3 oil at work, the reason wny Amsoil SS hs the top two spots is because Rats test only heats the oil, he does not run it through an engine. it is no coincidence Amsoil SS did so well in a heated test and noth 20 and 30 weight are on the top of the ist, it is also no coincidence so many guys engines are ticking on Amsoil, what would be coincidence is if the engine is ticking right away with Amsoil, because if my theory is correct, it should take a while before the ticking should start because in the beginning of a run those VII"s will be be bonded together, and as long as they remain bonded together, then VII's lubricate better then base oil, or in other words it would take more psi before fail for the VII's in base oil, then just base oil by itself.
This is the reason for my post awhile ago. Ok, Amsoil SS is great when new and maybe heated once. That's you're lab test. Now our lab test will be 5/6/7/10 thousand miles and a couple of hundred heat cycles later. Rats lab tests are fine to a point, but I prefer real world testing and how an oil performs in my engine, not a lab.
Sent from my XT1650 using Tapatalk
Burla
are we gonna start agreeing with each other more often?
Ramnewbie
Truth be told I agree with you more than you realize. It's just you're presentation when you go off the deep end that I don't agree with sometimes.
