Quick side note. I have redline Gear oil factory recommended oil weight in my Rear and Front Diffs of my truck. How many miles are these gear oils good for in the differentials?
My only question is: Do you tow?
If so? Are your loads med/heavy loads & for how many miles at a time.
Only real enemy of gear oil is heat/shearing/water contamination.
(Do you tow in 4WD? If not? Stick with the factory recommendations for the front).
(If you never tow at all): Just a daily driver for the rearend I would do my service every 50-75K miles.
If you have a Limited Slip: I would definitely do a service before or around the 40-50K mark.
(Clean/Fresh oil is a Anti-Slips best friend).
If you tow often & for quite long periods of time in both 4WD & 2WD my rule of thumb is do your service between 25-35Kmiles.
If you tow a boat & your rearend gets submerged in water often? I would do my service every 25K miles.
Your using one of the highest quality gear oils created: Your in very good hands!
Once again the SyN Disclaimer: Only My Simple Logical Opinion!
It sounds very complicated but it’s really not! Just don’t neglect your Differentials due too being Lazy!
ZF has made the service for both the front and rear differentials of the 1500 very easy no excuse not to do it now.
My ram is a different story: I’m having to install a new rearend cover to make the service much easier and faster. (30min Tops)
I honestly think (most owners) have no clue exactly how hot the gear oil as well as the rearend gets (while towing a medium or heavy load during the summer on asphalt for Long periods of time).
