- Apr 28, 2012
- 23,283
- 45,023
- 2010 Hemi Reg Cab 4x4
- Hemi
The right gas treatment with ethanol? The rub on ethanol is it can contain water, the white paper has of one piece of metal treated with s1-1 and one not. Rust inhibitor, PEA, and upper cylinder lube.
USE DIRECTIONS Initially use one bottle to a fuel tank and fill with fuel to achieve rapid cleanup. The treatment can be reduced on subsequent fillups to 1/3-1/6 oz per gallon (one bottle to 50-100 gallons) to provide continual injector and valve cleanliness. The detergents and antioxidants help prevent the formation of gum and varnish in gasoline, and the rust inhibitors prevent corrosion. Red Line SI-1 will not damage fuel system components and the combustion by-products do not cause corrosion of engine bearings as can many fuel additives.
