Rampant
Anything you don't like about this pan? The only minor thing I see is I would like it better if it used an o-ring seal.
Yeah, I mean a large, formed o-ring that goes around the perimeter of the pan, like many of the aftermarket differential covers use. There is no seal or gasket on the tranny pan from the factory. It just uses Mopar RTV sealant.You can use teflon tape or liquid thread seal.
I plan on getting one when I change the trans fluid. Maybe someone will make a cheaper one by then. All I want is a drain plug.
Me too, but it's not one of their mainstream oils. Not sure what "Specific" entails. If I had to guess, I'd say it meets some sort of stringent Euro spec.Damn, I had higher hopes for Motul.....
I'm an old aircraft hydraulics guy. O-rings alone are still used in static and dynamic systems/components ranging from 3000 to 4500 psi. When installed properly, there really isn't a better way to seal most any surface, and there is no sealant to scrape off when you change them. It wouldn't deter me from buying that pan, but o-rings are my preferred choice for sealing. Thanks for the info.I don’t really like relying on just an O ring for something like this weather it’s your differential or transmission. If I had a rings on it I would still use RTV.
There’s not a single thing I don’t like about it. I was worried how far down it would hang but it does not hang down low enough to worry about much hitting it. I have heard many logs clunking around under my truck and I’ve never had issues yet and this pan is very thick aluminum so there would be no issues with any logs you find. You could park your truck on it it’s so durable.
Three new 5w-20 test results for Havoline, Lucas, and Motul oils at PQIA.
The water pump on the 6.7 Cummins had the 0 ring gasket, sure was nice when I had to change it out.
You already changed the water pump?!?!?
2018 2500 6.4 4x4 4.10 Amsoil SS 0w-40
2016 Durango 5.7 AWD 3.07 Amsoil SS 5W-30
What does this mean for the hemi and Pentastar engine ?From Amsoil:
May 1 is the first licensable date for API SN PLUS. The soon-to-take-effect specification was requested by the automobile industry to protect passenger vehicles from low-speed pre-ignition (LSPI). We anticipated this change, and the current Signature Series, XL and OE synthetic motor oil formulations all meet or exceed the specification. Look for updated product labels featuring the new API “donut” in the near future.
You are running the #1 oil Brand and weight for you 5.7L Hemi imo Sir !Ive been using red line 5w-30 for a while now. Not sure if it does anything different than other oils but I hear good things about it so I use it.
I agree 100% , I'd be running PUP without a doubt if it didn't create my one and only tick ....very faint , but I never had a tick on Redline , so I just went back to Redline oil and my tick went away in just a tank or two .RLK: One thing for sure PUP has exceptional lower numbers compared to other oils.
That is one great looking UOA.
Even though it was only 2000 miles.
TBN was 5.6 this combo could easily withstand a 6K-8K mike OCI.
I have the Mag-Hyteck 45RFE Pan on my 65RFE. xsmn ( stock exhaust ) adds about 1.75 qts .Has anyone had a temp decrease using an increased capacity pan?
Sent from my LG-K540 using Tapatalk
Yep , I used the Mopar RTV ( GREAT STUFF IMO ) when I installed the Mag-Hyteck pan on my 1500s. 6 speed xsmn . I also used the cork gasket supplied by Mag-Hyteck.Yeah, I mean a large, formed o-ring that goes around the perimeter of the pan, like many of the aftermarket differential covers use. There is no seal or gasket on the tranny pan from the factory. It just uses Mopar RTV sealant.
Not much, for now. Basically, LSPI primarily affects GDI engines. Eventually, they say most, if not all engines will be Direct Injected. The technology does present a few issues, but they think the juice will be worth the squeeze once they get a few things ironed out. Oils don't cause the condition, but can have a big affect on controlling frequency and severity.What does this mean for the hemi and Pentastar engine ?
